1. On the "Adjust" screen, can you make it remember your last chemical selection, ie... I am always using 6% bleach but every time I enter the "Adjust" screen the default bleach is 5.25%. Can this be driven by the entry in the defaults screen? (suggestion from my last post)
My plan is to make it remember the last chemical selection you used.
2. When editing/viewing records, can you add "Previous" & "Next" buttons to cycle through the records
Definately doable, I will have to see how much work is involved.
3. When viewing a records list, can you add a confirmation for record delete. "Are you sure you want to delete this record?" I accidently deleted a couple records because of fat fingers and one time I fell asleep while playing with the app.
Yes, my wife suggested that also... There will be more error checking in the next version.
4. On the graph screen add a "back" button to bring you back to the "Charting Options" screen
This is already done on my internal version and will be in the next release.
5. On the graph screen, can you make it so when I tap a data point it opens that record?
I will see if that is possible.
I am probably at least a week from releasing another version.
I am currently making some major changes to the charting engine.
The next version will allow you to chart the effects of your adjustments (as bar charts) against your measurements (as line charts.)
It's kinda of a PITA because I have to rip out alot of the existing charting code to make this work the way I want to.
I can probably also include the code to save your last adjustment selection at that time.
There will also be a number of smaller UI enhancements.
Again, I really appreciate your suggestions!
-Ken-
