I'm making gaskets. Does it really if the outer diameter is "too big"? The gasket will be same inner diameter as hayward fitting and the outer diameter will be approx. 1/2 inch larger than the diameter of the fitting. And it will be ugly.
Nice work
I do not think there is really anything to be gained by having the gasket that much bigger than the nut, but glad it is sealed up.
I stand by my statement ... the 1/2" or whatever exposed red gasket outside the nut is not doing anything. You could go lift it and put your finger behind it so it is clearly not needed. I do not know what the inside looks like though.
I understand it was a hassle to get it sealed, but it was not the extra on the outside that got it to stop dripping now.
I've added a second hose clamp. It's the other type of clamp the brass wire looking kind. I also made sure it was as close to the end as possible so that it would be on the flattest part of the hose adapter. Then I clamped it the heck down.
Waiting now to see if that solves the hose leak problem.
