- Aug 8, 2024
- 274
- Plaster
- Pentair Intellichlor IC-60
Would it be acceptable or recommended to plug off my skimmers and or install ball valves where the skimmers come into the pump house? My thinking is if I shut off the auto top off, plug both skimmers, install a ball valve to bypass the filter or even just let it run through the filter then discharge out the waste port on the multi port valve ?
I have a sump pump that I’ve used in the past but it will probably be a lot faster using the pool pump??
