It appears the only solution to high CYA is to drain a pool. Yet, draining a pool even a few inches is extremely expensive. Besides high replacement water costs (at least $2000 for my 40k gallon pool), now you need a whole new set of chemicals to rebalance (calcium hardness, chlorine, acid, etc etc etc). CYA reducers must be much cheaper but yet most say they dont work? Besides needing more free chlorine, which during winter and cold water temps is not an issue,why is high CYA (at least not above 300ppm), a problem?
