I'm new to pool maintenance. Bought a house last fall and my wife and I thought our pool pump broke two months later. Our intent was to resurface the pool this spring and replace the pump... so we let the pool go over the winter. Turned into a mess. Even had a family of ducks frequenting it at one point, hah!
I was able to get the pump running last week after YouTubing possible causes of pool pump failure and figured out the motor had seized. After a lot of moving the shaft back and forth to break up whatever was in there - I was finally able to turn it on and jump-start it. Still need a new pump, but it's working now.
With the markets taking a beating lately - we decided to put our pool renovations on hold. We still want to swim in it this spring so I started the process of learning how to balance the pool chemicals. The first thing I did was measure the FC - which was 0 - and then the CYA - which was way above what my Taylor test kit could read. Probably in the 200+ range. Based on the CYA reading, I knew I had to replace the water. I cleaned the pool, drained to a little less than half, and then filled it back up. After that I got the following results:
FC - 0
CC - 0
PH -7.8
TA - 100
CYA - 45-50
CH - 300
Just for fun, I brought in a sample of the water to the local pool store and their results matched mine (phew).
Since the PH was high, I used muriatic acid to lower it to 7.4 and then SLAMed with liquid chlorine. Brushed, vacuumed, cleaned filters, and repeated several times throughout the process up until Monday (2 days ago). Pool looks amazing now. Even better than when I bought the house, heh...HOWEVER... my new test results are:
FC - 8
CC - 0
PH - 7.2
TA - 80
CYA - <30 (can't measure since the lowest on the test tube is 30 and I could still see the dot)
CH - 300
I figure the FC will continue dropping to acceptable levels. Not sure why my CYA levels dropped so much though. It has rained a few times - pretty hard for short periods of time - over the past few days in North Texas. I wouldn't expect that to drop CYA levels so low.
The pool store recommended cal-hypo to shock the pool, but after watching a Youtube video on someone turning a pool from green to blue with liquid chlorine that had similar chemical levels as mine... I opted for liquid chlorine. My CH levels were right in the optimal range so I didn't want to take a chance and raise the CH levels unnecessarily.
Curious what yall think I should do moving forward? Do I simply add chlorine stabilizer and continue with liquid chlorine? or when the chlorine levels get low - switch to di-chlor or tri-chlor tablets to help raise CYA?
I know I need to get my CYA levels up. Just not sure what the best approach to do that is.
Pretty proud though of what I've done so far without spending an arm and a leg by hiring a pool service. See below for before and after
FC - 0
CC - 0
PH -7.8
TA - 100
CYA - 45-50
CH - 300
FC - 8
CC - 0
PH - 7.2
TA - 80
CH - 300
