If I remember correctly, you are both really busy during the week - so....
***disclaimer***
*****the following is not TFP policy, but works for me
*******During the week, if you simply refuse to at least test FC, just pour, each day, 4ppm worth of bleach in the pool while pump doing it's normal 2-4hr cycle, or whenever it is running. I have my pump run when I know I will be there, so if, on the days i can't care for it properly, i can at least dose it. 4ppm for 10k gallons is like 59oz, which in my fast-paced world, is half a gallon. Better you pour it slowly, to be sure, but in my life, when the decision is sometimes 30 second or nothing at all, I admit, I dump half a gallon in about 30s and run away to my day. Is this a little wasteful in bleach budget, yes. Is this potentially too fast to pour in front of return, yes. Might this ultimately hurt the plaster a little, yes. Will I live with it, yes, I already know I have to redo it one day. In the future, when you get your pool balanced, you'll be able to extend dosing to every 2 or 3 days if you wish - but that requires writing your test results down and averaging daily FC burn and adding enough to cover it for a few days. Anyway, my main point was, just because you can't test daily, doesn't mean you're allowed to let FC drop below min. You CAN dose it, you have time.
****end non-tfp advise
***disclaimer***
