- Jul 8, 2013
- 94
- Vinyl
- Jandy Truclear / Ei
When I inherited our pool a few years ago I found some paperwork from the previous owner that stated 30k gallons. I also measured and punched the data into the volume calculator and ended up around 30k as well. Our pool is vinyl with a 8ft deep end and 4ft shallow, but it slopes down as well as the sides slope down in the deep end rather than straight down. I imagine that's typical for vinyl, but I wonder if those slopes are cutting out more volumes than I thought. Lately I've noticed that I'm overshooting my chemical goals with certain tests, like FC. This makes me think the pool is smaller than I believe. If I use the PoolMath app to estimate "Effects of adding X" then see if that amount matches reality when I add said chemical, is that a good way to double check? I know tests like salt have a large +/- so maybe that isn't the most accurate, and I would guess same with CYA. However is FC with bleach a more accurate chemical to test with that has a smaller margin of error?
