Got an 24' 52" AGP about a month ago. Got poolstored
for Pristine Blue. My bad as I did not do enough research prior to pool install and opening. Just too excited to finally have a pool.
After joining TFP and doing some reading I want to convert to BBB.
I have been the perfect chump
, taking samples to the PS every 2 weeks and always having to add something, something expensive.
As of yesterday my chem according to the PS was:
pH 7.7
Hardness 130ppm
Alk 90ppm
PrisBlue 0.3ppm
They directed me to add 57 oz. muriatic acid, 1lb 6oz. non chlorine shock, 18 oz PrisBlue, 2.7 oz Pristine Clean.
I did this like a dummy but the muriatic acid gave me the creeps and I started into some more in depth research on PB.
EEK! I put it all in at the same time! In different areas but augghhh! Lucky nothing blew up.
Prior directed chem addition to date have included:
16 lb. CA+ H20 hardner at opening
A total to date of 64oz. PB
4-6 lb. Baquacil
4-8 oz Pris clean.
Several doses of non chlorine shock.
Will get chem rechecked today by someone else and will post those results.
Must admit water is sparkly blue but I get the creeps just looking at it.
Thanks in advance for any help.
pH 7.7
Hardness 130ppm
Alk 90ppm
PrisBlue 0.3ppm
4-6 lb. Baquacil
4-8 oz Pris clean.
