I have owned my house and pool since about 2004.
During that time I have done no maintenance or work on the pool surface. At one point, maybe about 10 years ago, before I was doing the daily pool care myself, my pool guy said that my pool needed to be painted. I never did it.
I would guess my pool was built in the 1970's.., but I really don't know. It is a kidney-shaped pool.
The pool surface is very hard and pretty smooth- it's either concrete, or maybe plaster over concrete. It may have been painted at one point -i see a few little areas where it looks like maybe peeling paint, but these are tiny - from even a few feet, the surface looks fine. I do have some areas of staining, that don't come off by brushing with a wire brush, but these are not that bad.
my main problem is that when I brush the sides of the pool with the wire brush, a very fine white powder comes off and clouds the water. My cartridge filter can take a day or two to clear this if i do a lot of brushing. So, I tend not to brush the sides very often, which is not great for algae prevention.
I have not been having much trouble with algae - my CC is low, even after brushing.
could it be really old paint that is coming off when i brush?
Going forward, I guess I have two choices: re-plaster (assuming my pool has plaster).., or paint. I understand that TFP does not recommend paint. As an aside - I put two-part epoxy paint on the bottom of my racing sailboat - it's extremely hard, and burnishes to a very smooth surface.., so I have trouble understanding why a similar paint won't work on a pool - but i will take your word for it.
I have a very high water table - there is a stream about 20ft from my pool, and the typical water surface of the stream is only ~2ft or less below the water level of my pool. Sometimes in the summer, the stream dries out completely (not this year-so far) but even then i doubt the water table is ever more than 4 feet lower than the water level of my pool. I have had about 3-4 feet of water out of the pool to reduce CYA - but I was nervous and replaced it right away
So I am not sure what to do for my pool.., nor even if I can do anything - given my water table...
any suggestions?
any suggestions?
