- Jan 4, 2016
- 5,392
- Plaster
The pool store sold me a bag of Supr-Magick-Sparkle, for just a little extra insurance and to be on the safe side...
Just kidding, but there are common pool chems recommended at pool stores that cause problems and are not necessary. Here's three to avoid:
Copper algaecides and other copper containing or producing products
- cheap and nasty algaecides, often with 'blue' in the name
- they can cause staining of the pool surface and cause blonde hair to turn green
Ammonia containing algaecides
- there are only rare circumstances when algaecides with ammonia will work
- in terms of results, plain bleach or pool chlorinating liquid can do everything that these algaecides can do
- it take a lot of chlorine to get rid of the ammonia afterwards
Bromine
- this can include bromine tabs and granules, sodium bromide, and some products with 'yellow' in the name
- if you're able and willing to run a bromine pool or spa, then by all means, keep up your sanitizer
- but if you're using chlorinating liquid, bleach or a salt water chlorinator, the presence of bromide is a headache
Powdered shock
- include cyanuric acid or calcium
- these can be useful, but be aware of how CYA and calcium work in a pool
- chlorinating liquid or bleach are usually better alternatives, and they're cheap and easy to understand
The wrong approach can require draining and refilling a pool, and/or much higher cost than necessary.
We see a lot of threads here at TFP after pool stores have recommended these things without any mention of the risks. Labels usually don't mention the risks either.
Feel free to mention it here before adding it to your pool if you're wondering if it's right for your situation.
Bromine
Powdered shock
