I purchased a Dolphin S300i to replace my pressure side cleaner and I am happy with it for the most part. The one real issue I have is the cable swivel does not seem to be working and the unit gets tied up in knots. Is there something I can do?
Where is the swivel? I have the white cylindrical looking plastic piece close to my robot but I do not feel anything that twists.Its just inevitable. You can minimize it by lubricating the swivel very well with silicone base pool lube.
This is exactly what I needed, thank you. I had a mind yesterday to try and take it apart like the video but I did not wasnt to screw anything up and was not 100% positive it was supposed to come apart.Do not lube the gold plated terminals. Push the blue cable through the swivel and fill/lube the bottom and reasemble.
I'm seeing the same issue... like it's resisting swiveling and the cable tangles up after a couple of cycles, even with proper coiling (over-under, AV guy style).Do not lube the gold plated terminals. Push the blue cable through the swivel and fill/lube the bottom and reasemble.
