I picked up a new bottle recently at the local PaP, same percentage as always but a different brand. I noticed it doesn't smell nearly as strong and I believe it's not dropping the PH near as much as it should based on Pool Math.
31.45, same as the other stuff. So as an example, last night I had PH of 8.2. I added 7 oz to get down to 7.5 PH, this morning it was 7.7.You may have perchased the "lower strength" green stuff.....which means you have to use twice as much to get the pH adjusted.
What is the percentage?
Maddie
