@Ahhsomeguy ,
Here's my question, then below is my tub's info.
I did not use Aqua Clarity to do my purge, I used the AHHsome! packet. But today, finally mixing up my Aqua Clarity to give my tub it's first 'Weekly' maintenance dose of Aqua Clarity, I THOUGHT I read the dose for doing a purge as 3 oz/200 gallons* and the dose for the weekly maintenance is 1 oz, 200 gallons. * My misreading the purge dose as 3 oz/ 200 gallons. prompted this question. Now, just now re-reading the instructions and seeing the dose for doing a purge is actually 3 oz/ 100 gallons, my concern is 50% less ;o). I've gone this far, so I will ask if having 17% of the 'purge amount' running in the tub full-time has any significant ill effect on headrest degradation over and above just the normal amount of degradation over time (years) that just regular Bromine or Chlorine sanitization causes? Initially thinking the maintenance dose (from my inattentive reading) was 1/3 as strong as the purge dose, made me fear for my headrest's quicker degradation. Oye!
A second unrelated question. Now that I have bought some spare filters and will be swapping in a fresh cleaned filter, at least weekly*, and I have not purchased a 'filter cleaner' product as yet, I want to ask Aqua Clarity is as good a filter cleaning product as any specifically designed for that purpose. *I will change/swap the filter evry 1-2 days after my delinquent first AC 'weekly' dose today. I have not looked into 'filter cleaning products' yet. Maybe there are even products around the house that work as good as overnight or longer soaks to clean filters, I don't know. Not positive, but I think I have read that some people put their filters in their dishwasher and report good results from that.
I did recently buy a Filter Flosser hose spray tool $29.95, for easier rinsing of filters. It works much better than the plain spray nozzle.
Tub and maintenance Info:
I started my brand-new Bullfrog A6L (310–335 gals) the first week of Feb. 2024. As recommended prior to doing the purge, removed all the headrests, so as not to damage them with the strong purge chemicals. Then I did a thorough AHHsome! (packet) purge. Ran jets on high 30-mins., cleaned green gunk from shell and surface. Ran jets on high again (no additional product added) and got a tiny bit more green gunk, cleaned that out, drained, vacuumed all water out, rinsed sides and sprayed in all jets, drained and vacuumed again. Then filled the tub w/310 gals of water, took two days to drop the TA from 370 ≈70 ppm, then did my bromine bank, shock, etc.
Now 3 weeks later, I am finally just getting around to mixing my Aqua Clarity into it's 1 gal container and gave my tub its first 'weekly' treatment. I had just finished ready an AHHsome! discussion that referred to using 2 oz for a four hundred gallon tub (1 oz. /200 gals). Dooooh! I had 2 oz. stuck in my head and added that to my ≈ 335 currently in the tub. Ooops. Not a big deal, as it is only a slightly high dose, but I was pleased to see that after 10 mins of circulating (both jets on low) for ≈ 10 mins (no foam to speak of on surface), then I rand both pumps on high for ≈ 5 mins. There was still no foam to speak of remaining after the bubbling calmed down after pumps were turned off.
