I have attached a photo showing a bubble coming from one of my microbrite lights and an arrow pointing to the approximate location of its origin. (I tried to upload a video showing them streaming, but I had no luck adding a video. ) The light still functions normally. I contacted Pentair to see if this is typical. I’ve never noticed the bubbles before, but this one and only time I’ve witnessed this, it was shortly after turning on the lights and lasted for 10-15 minutes max. I was thinking maybe it was from this recently illuminated “heat source” in the water, then whatever was happening to release bubbles finally balanced itself out (if that makes sense). Pentair is sending someone out because they feel it’s likely a problem with the light. The thing is - I believe the entire wire has to be pulled to replace this light - not just replace the head unit. YIKES! If these people don’t know what they are doing or screw up and wreck the conduit, I could end up with a leaking pool right before winterizing. Not a happy thought.
Does anyone know any details about the replacement process, or this bubbling event? I’d love to hear that this is normal, or that I’m wrong about a full wire pull being required.
Thanks!
Thanks!
