Pool has been out of commission for over a year due to a construction project. Tried to keep it covered with tarps but eventually the reality of the construction work won out and the pool was left exposed to construction debris, mud, concrete dust, etc. Finally got the equipment hooked back up and I'm trying to get it clean now. I drained it about 2/3 of the way back before the equipment was working and used waders and a net to scoop as much gunk, leaves, and construction debris out as I could find. I think I got all or the vast majority of the non-organic debris, but there's an unknown amount of mud and leaves still down there that seems never-ending when using the net. And I haven't seen the bottom of the pool in a year, so I can't tell for sure. Mostly it seems like a ton of mud.
I hoped I'd gotten enough of it that I could fill it back up with fresh water, start it circulating, and filter the dirt out that way, or at least enough to be able to see what I'm dealing with. But adding water didn't dilute it enough to see any better. It's just brown muddy water. The sand filter gets clogged every 15 minutes or so and needs backwashing, with no visible difference after a few days of trying that. Running the Dolphin doesn't do much, as it takes 90 minutes or so and comes up full of mud, but likely only makes a dent in the amount remaining.
Running it on waste setting and using a manual cleaner head clogs the pump basket within about 5 minutes with leaves and debris, which means stopping the pump to empty the basket, re-priming and starting again.
I've been really hesitant to empty the pool completely because of concerns over floating it. But at this point I feel like I'm running out of ideas.
Thoughts? What would you do?
Thanks!
Thanks!
