We might have put the cart before the horse, but we happened upon this playground slide and want to use it as a pool slide.
In trying to come up with a plan for a support structure we have determined that it (just the slide) stands just under 8’ tall when sitting on the ground. This footprint is 78” wide x 62”(ish) deep.
How far does the bottom of the slide need to:
1. hang over the water/edge of the deck; and
2. be above the pool deck?
Add’l Info:
From top of deck to water level is 6”.
Water depth at deck is 40”.
Water depth 1’ from deck is 44”
Water depth 2’ from deck is 60”
Pool is 9.5’ deep. (40’ x 20’)
No small children use the pool. Just teens and adults.
We are thinking the platform to enter the slide will be 36” x 36” and we want a top railing height at 42” high (from the top of the platform) and 2 or 3 add’l rails between). Are we on the right path?
As for water, would a drip hose mounted to the interior on opposite sides (12” up?) the length of the slide suffice?
Any feedback or suggestions appreciated!
Add’l Info:
