Stopped for lunch....then we went to see the USS Salem in Quincy MA - heavy cruiser they have on display
Then to HD for a few more bags & back to work
I patched the long thin crack in one deep end corner
I have a very small baseball sized hole at the bottom junction with the floor to still do
Water is actually coming thru the hole, might need hydraulic cement to patch that
I also patched one of the small holes up near the wall, I enlarged the hole 1st to pull out any loose sand etc
Then really packed the cement in there to totally fill the void, after that I started on the really bad side of the deep end
I got maybe 1/2 of the bad side done, this is the last really bad area to patch
Dinner time & I decided to call it a nite, much easier doing this in the daylight
I've just about finished using ~250 lbs of dry mix, not sure how heavy that is once mixed
My back is feeling it a little, its the bending over to mix & apply that really gets ya
Last pic for the nite is the lite on the North wall
I saw the moon was out so decided to take a pic, using the flash actually made the sky look darker
Just not the best pic for seeing what the lite looks like
