- Apr 21, 2021
- 122
- Plaster
- Jandy Aquapure 1400
In an effort to not spend the $1,200 my PB wanted to put in an auto fill, I decided to do it myself.
I purchased a reduced pressure backflow preventer, tapped into my outdoor hose spigot and then plumbed it to the pressure side after the pump where my builder had the discharge valve. About 2 hours of work between soldiering the copper pipe and adding the PVC connection.
Tomorrow I'll run an electrical outlet nearby for the automatic valve turner which I added on top of the backflow preventer. This allows me to control it from my phone. Next will be a wireless water sensor which I'll integrate to the valve to fill if the level goes below the sensor.
My incoming water pressure is 70psi. Running pump at 4350 RPM I can feed the pool at 4GPM.
If pump is at 1500 RPM or lower it feeds at 6GPM.
Backflow preventer was $300 and the smart valve was $40.
