- Jul 29, 2017
- 261
- Plaster
- Pentair Intellichlor IC-40
I slammed the pool in late October and closed it. I still have too much chlorine to get accurate pH readings.
Everything I read on here says you can dilute the pool water 1:1 with distilled water but at that ratio I still have bad readings. I had saved a post by Ben on the old forum many years ago where he said it was ok to go to 1:2 pool:distilled when chlorine was really high. When I do that my pH reading is 7.6 which is a little higher than where it was before I slammed.
Can I trust that is close enough? I do not want to run the risk of scaling over the rest of the winter and I don't really want to get the Apera PH60 just for the few times I can't use phenol red drops.
