Disappointed bubbler
Jan 4, 2018
48
Pearl/MS
CircuPool Edge-40
Okay, 🤦‍♂️🤔😏. ..
So, I have a bubbler on the tanning ledge...... it’s controlled by an actuator... I make no changes to the actuator or valve.. and it starts the day strong!! Nice flow!! However, two hours later, the bubbler is at least 2-3inches lower then when first started. Later in the evening, the bubbler barely breaks the surface with no changes... what gives??
Okay, 🤦‍♂️🤔😏. ..
I see you have a VS pump. Is your pump changing speed throughout the day thus lowering your output to the bubblers?
Reactions: RDFBocephus
Haha thanks! Speed is the same. I think I figured it out. We also have a AOP system (i know, I know 🤑) with ozone and UV. I think there was a buildup of ozone bubbles in the bubbler line and reduced the flow. Tested it this morning, bubbler started to go down so I increased the pump speed for a few minutes to purge the line, reduced pump to normal speed and it’s back to normal.
Reactions: HermanTX
