My pool in-ground Gunite and white pastered pool was brought back from the dead after I purchased it with my house almost 6 years ago. I've been using TFP procedures and guidelines the last couple of years and the pool seems to be well in control and very predictable. There has been a "tint" to the plaster since it was well cleaned and acid washed by a pool company directly after my purchase. The tint is slightly blotchy but in general is a slight tan color. In addition, there are probably eight spots about 2 inches or so across that stand-out on the bottom and they have a "rust" appearance. These abnormalities have been very consistent since I've owned the pool.
I recently learned from this site that Ascorbic acid can be used to remove rust spots and that trying vitamin C tablets on a stain is a good indicator that the stain is indeed iron. Today I bought some vitamin C tablets, put maybe 1/4 cup of them into a white sock and placed the sock over one of the "rusty" spots. I did this with the pump off. About 45 minutes later the spot turned from a rust color to an almost black color with about the same intensity. The most interesting thing is that the plaster near the sock and "downstream" was "bleached-out" and noticeably brighter.
What does this say about "rust spot"? What does this say about the discoloration of the plaster? It seems to indicate that the plaster discoloration is iron staining but that doesn't make a lot of sense because the water used to clean and fill the pool was local tap water that seems to have almost no iron content whatsoever. It sure would be nice to "brighten" the pool!
All thoughts and suggestions would be greatly appreciated.
