Installer Menu:
To enter the Installer Menu, press and hold SELECT button for approximately 13-seconds.
Press MENU, press or until “Installer Menu” is displayed
Press and hold the SELECT button for approximately 13-seconds.
Press or for desired selections, followed by SELECT
Once all modifications are complete, press or until “Exit Menu Mode” is displayed; then press SELECT. Please note - the menu will time out after 20 seconds of no
key activity and any changes may be los
Pump Control:
1. Press or
2. Press or
until “Set Pump Control” is displayed; then press SELECT (external timer is the factory setting).
until the desired pump configuration (One-speed pump, two-speed pump, remote runs pump or external timer) is displayed; then press SELECT.
(Program DIG-220 to accept a one-speed pump, two-speed pump, remote, or external timer) Note - optional pump relay must be installed.
