- Jul 9, 2018
- 22
- Fiberglass
- Pentair iChlor 30
In another thread I recently resolved a bad flow switch problem with our SWG, and while doing research I read a lot about deep cleaning the sand filter. It has not been done in our years of ownership and all the things I read suggested doing it once a year.
I disconnected the sand filter - a Pentair Sand Dollar SD80 - from everything and proceeded with disassembly. Got the clamps off just fine, and with some slight turning and pulling the valve assembly started to come up. Here is where I think things didn't happen as they were supposed to, as the valve assembly did not come off of the stand pipe. as I pulled up, the laterals came up out of the sand. (see picture) The videos I watched showed valve coming out without the standpipe, but for the life of me I can't get the pipe to budge out of the valve.
From more reading it seems I'm going to have to remove the sand to put the laterals back where they belong, but the only way I'll be able to get the sand back in is with the valve off the pipe. Am I missing something really easy? I'm hesitant to pull too hard and cause damage to the laterals.
