Hey there.
So we did Nitros decontamination on Saturday and followed to the letter.
On the fresh refill our baseline readings are:
CH - 70
FC - 1.5 (residual from pipes and the shock on the previous clean fill we think )
CC's - 0
TA - 40
PH 7.7
CYA - 0
We added 50 ppm calcium increaser and this took CH up to 120ppm
We added TA + and this took TA up to 50 ppm
We added enough chlorine according to the bottle instructions to take the ppm up to 10 on the new refill to dichlor shock it.
We ended up with 13.5 ppm somehow, so thinking the chlorine tub chart isn't accurate or maybe the testing ? We're testing with the Taylor 2006 kit.
Readings above were taken late Saturday night.
Reading early Sun morn:
FC -13 ( a loss of 0.5)
CC - 0
TA - 50
CH- 120
PH 7.6
We added nothing to these readings as thought all ok ?
Mon Morning readings: No one had used the tub
FC - 9 ( loss of 4ppm since Sun morning)
CC - 0 - 0.5 ? (we had a slight pink hue - not quite the same colour as when we have 0.5 cc's but there nevertheless )
PH 7.5
TA 50
Nothing added
Mon Eve: No one had used the tub
FC - 6.5
CC's 0 - 0.5 ?
PH 7.6
Nothing added
Tues AM: no one had used the tub
FC 4.5
TA 50
PH 7.6
CC 0 - 0.5
Nothing Added
Then after these readings we had 2 people soak for 40 mins in swimsuits, no make up body lotions etc.
Results after soak were:
FC - 0
CC's 0.5
PH 7
TA 50
Do these reading seem normal ? No one used the tub until this morning (Tues) and it seemed the decontamination worked but then the following nights we saw big losses of over 1ppm FC and some cc's started to show up without use ( I read that if it's more than 1ppm on the overnight FC loss test that it needs shocking ? Or am I misunderstanding this and driving myself round the twist with information)
Are we doing something wrong here because I don't know how many times we've deep cleaned/shocked this tub and then things seem to creep right back up very quickly ! Is this rate of FC loss normal after a large dose of dichlor on refill ?
If someone could please offer some insight I'd be really grateful because I'm about to give up with this tub ! :shaking:
CH - 70
CC's - 0
TA - 40
PH 7.7
CYA - 0
CC - 0
TA - 50
CH- 120
PH 7.6
PH 7.5
TA 50
Nothing added
FC - 6.5
CC's 0 - 0.5 ?
PH 7.6
Nothing added
FC 4.5
TA 50
PH 7.6
CC 0 - 0.5
Nothing Added
FC - 0
CC's 0.5
PH 7
TA 50
