Hello all,
New to the forums. I've searched and found a lot on bonding, but nothing specific to my experience. ild
I just had my in ground pool built. It is a vinyl liner with salt water generator and heater. The pool was bonded by an electrician. I inspected the bonding and process. The entire perimeter loop was installed, the bonding wire was fastened to the metal walls in four places, the diving board, cups for ladder, auto cover, and all equipment is bonded with #8 solid copper. There are also several direct bury pool bonding lugs in use. I believe that the perimeter, shell, ladder, cover and diving board were a continuous loop. Cant be certain. That wire connects with another wire that goes to my pool equipment. From there there are several connections made. I'm not sure why so many connections, but they are done with the appropriate bonding lug.
So I noticed I get a tingle with open skin, while touch my pool deck and the water or the ladder and the water. I measure with my meter set on VAC, one lead in the pool and the other lead on the ladder the voltage fluctuates between a half to a full volt AC. I should also mention there is a water bond installed. Its connected with the #8 bonding wire. Its an inline sacrificial water bond.
I was concerned the water bond wasn't working due to the water being at a different potential than the other bonded parts of the pool. To make sure that the water bond was connected to the bond around the pool, I took a long #10 wire, and connected it into the water bond lug, ran it down near my pool and measures resistance from that wire to the ladder and measured .4 ohms. I also did this same measurement to the bonding wire on the auto cover frame and measured the same.
This baffled me because that indicated that the #8 bonding wire was in fact attached up at the water bond and down to my pool. While doing this I noticed something. With on lead in the water, and the other lead just sitting idle on the deck, my meter was reading about .2VAC. I took the other end of the #10 wire that I was using to measure resistance, I dropped it in the water, and my meter dropped to .05 or lower VAC. I measured one lead in the water and one lead on the ladder, and it was about .1VAC, down from between .5 and 1. Also with the other end of the wire directly in my pool water the shock was barely noticeable.
I than stripped more of the #10 wire back, from .5 inches previously to about 3". The voltage dropped even more and the shocking went away. This had me believing that the water bond wasn't working. I'm not sure this is entirely far, as water has more resistance than my wire, but if the water is bonded, I shouldn't see this much potential difference.
I contacted my pool contractor and we walked through the bonding process, and my pool is the same as every pool he installs, using the same equipment. I was a little suspect of the location of the water bond, which was after my chlorine generator. Right after my heater is a check valve which should keep the pool water in constant contact even when pump is running. Oddly enough, the values for voltage and shock are the same when the pump is running or not running. So even with the pump off, if that plumbing bled off, surely with the pump on that pipe would be full.
I've gone back and forth with electrician and pool contractor, and there very well may be stray current in the ground, which is probably more than likely, however the pool bonding process is supposed to mitigate this. I did disconnect my main switch to my house and the shocking and voltage potential exists. I have not disconnected neutral from my house from the utilities yet, but this might be a next step.
What has me really baffled, is why can I drop a wire in the pool connected back at my water bond, the water seems bonded, but without it the water is not bonded. The pool contractor agreed to install a second water bond, closer to the pool and below the water level. This second water bond had absolutely no impact. In fact, if I connect my meter, and disconnect or reconnect the water bonds, the change is minimal. I drop a wire connected to the bond wire, in the pool and the issue is totally eliminated.
I have LED lights in the pool, fiberglass steps, and in wall ladder with hand rails. No ladder connection to the pool water. I'm open to any and all suggestions. Sorry for the long post, but wanted to cover everything, but its possible I left something out. I've done a lot of testing, and can't help but feel this is a very simple fix, that i'm just overlooking.
