OK. Watch out that you don't get the CYA too high with the tabs. We usually recommend liquid chlorine over tabs to keep a lid on CYA intake. But you might be "lucky" enough to get sufficient rain to flush the excess out, your current CYA level looks OK - but that's after winter.
The test strips are more guess strips. Best test kits are those that allow titration tests for TA, CH and FC (FAS-DPD test, accurate and reliable up to and beyond SLAM level), like the Taylor K-2006. But I've read a few posts recently that it seems to be quite difficult to get decent test kits in the UK.
The Poollab seems to be a viable option should better kits not be available. I actually have one myself, but don't really use it. Bought it more out of curiosity. My experience with it:
pH test seems to be pretty good, but will be affected by higher chlorine levels sooner than the Taylor pH-test would.
FC seems to be OKish, but limited to 8ppm (dilution with distilled water allows testing of higher levels, but with reduced accuracy and more effort). It seems to take a while until the tablets are fully dissolved and the reading stabilises.
CYA seems to be in the ball park (at least more than test strips), I'd say within about 30%. But I haven't tried that much.
The test that seemed to be completely off was TA (showed 40ppm when my titration showed 80ppm). But you could make an aquarium test work there (there is one from Red Sea for example) if you can source thiosulfate dechlorination drops (aquarium tests don't have to worry about chlorine). If you can't get thiosulfate, then hydrogen peroxide might have to do, but I haven't tried if that creates any interferences with the TA-test.
I haven't tried the CH-test. But there are also aquarium tests that could be an alternative (e.g. Red Sea again). Aquarium tests usually use different units (like ppm Ca instead of ppm CaCO3), but they can be calculated into pool-units.
I found the Poollab less accurate than the Taylor titration tests and more fiddly to get those tablets dissolved without scratching the test vial. But an option, should nothing Taylor like be available. Best option would be to source a Taylor K-2006 from the US (not the K-2005, that doesn't have the FAS-DPD test, only DPD). But that could be pricey or even impossible. Or another brand that offers FAS-DPD testing for FC.
