Hi guys, i'm trying to find a new pump but a bit clueless on some of the electrical stuff.
My current pump for my above ground pool is a 2HP Hi-Flo --- 115 Volts, 13.8/3.8 Amps.
My current outlet shows 20 Amp, 125 Volts.
I think i can move to a 1.5 HP Pump as my pool is only about 10-11K gallons.
Questions:
1. Is there anything i need to know about a new pump to make sure it works on my current outlet? Just something with top speed below 20 amp?
2. Current pump has a L5-20R Twist Lock. Finding that a lot of newer models are L5-30R. Should i just buy a new model and cut off the cord and install a new twist lock? Is that a tough job? I mean i can change out a light switch.
Any help appreciated. Thanks!
Questions:
