Once again after three years of replacing I’m having issues with my pool vacuum. This is the second one in 8 years. Looking at rebuilding it but I would be spending around $250 to rebuilt with no guarantee that it will be fixed. Had similar issue back in 2020 which after rebuilding the issue remained. Issue now is that it just goes in circles and hardly climbs the walls. It is connected on its own vacuum side line. Even when I fully close the skimmer valve, you can hear it oscillating very fast but does same thing. I did make sure nothing is blocking the internal as I took it apart.
So instead of fixing, I’m thinking of getting a replacement with vacuum side again or newer electric technology. I do get a lot of debris from surrounding trees so it needs to be able to handle such pickup. Any recommendations? Thank you
