DE out of return
Jun 25, 2017
43
Montgomery New York
I recently started a SLAM and I noticed that after backwashing there is a small amount of DE coming out of the returns closest to the pump. I have a DE4800, for which I understand the fresh charge should be 5 pounds of DE, and after a backwash I add about a pound of DE. The grids were replaced right before I started SLAMing (about a week ago). I just read the filter cleaning stickie, and realize that I should be alternating backwashing with rinsing, which I have not done. Could I be adding too much DE?
After backwashing, you should be adding about 80% of the full amount. So you have been adding too little, but you have also not been doing a very thorough backwash, so likely ok.
Did the problem start after you replaced the grids? I would suspect something not quite right inside the filter.
