- Jul 14, 2011
- 73
Well we are going with your recommendation. Drain and fill and start over. Yipee.... Maybe then we can get somewhere. I may be back for more advice. I was on here a lot previously a few years back when we had the dreaded baquacil that would not clear up so we did a switch to chlorine. That was fun. I think you may have helped us at that point. Right now. Our water is cloudy. When the pump is off it settles to the bottom and the water is clear. I posted our chemisty to you earlier. Pool was very dirty upon opening with tons of leaves that were all vacuum out. We had clear water for a week but the pump was only running for 1 hour and then needing a bump.
Sent from my SPH-L720 using Tapatalk
