So how exactly will I know that??Another option is to sand with a power sander and diamond grit pads.
I would probably do a Jack’s #2 followed by a drain and sand with fine grit diamond pads.
Note that draining always involves risk and you need to be sure that the pool will not float or have any other adverse effects.
Yes this is exactly what it is. I have Ajax magic stain ID kit coming, but it doesn’t arrive until March 31..
Get a local service person who knows the ground water situation.So how exactly will I know that??
But how does one “lift the stain” considering it’s such a large area? Like do I now just dump in a ton of this copper stain solution?Basically - lift the stains, drain the pool, refill with metal free water … and make sure there are no copper products ever used in your pool.
