So I'm doing a new fill of the hot tub and going through all the steps being extra careful with my measurements to try to avoid what happened last time when I overshot the salt by 400ppm and almost ended up having to drain a bunch and try again. In the process of getting the water set up, I noticed something that had slipped past me last time. The Damp Rid I've been using to balance the calcium says it contains "Microban" and is only 78% calcium chloride.
Does anyone have any idea what else is in this stuff? I'm not going to use it this time, since my tap water is about 120ppm calcium anyway and my spa is acrylic, so according to everytjing I've read on here I really don't need to raise it anywhere. I only added it before because the SWCG manual says to keep the calcium between 200 to 400 ppm and it was an easy enough adjustment to bring it up to 200ppm. Could this have been related to my issues last time getting the water balanced and the salt levels correct? I think the "Microban" ingredient is primarily urea based on what little MSDS data I've been able to find. Any idea if that would be a problem in my tub? Honestly, once I got everything leveled out the water was just as steady and easy to maintain as with the purer all CaCl DampRid, but given my heater problems I'm a little jumpy about weird stuff in my water.
