Hello everyone,
I’m a third year pool owner and I have struggled every year keeping my pool clean. I went to my local pool store at the beginning of the year and I think they sent me down an off path. My CYA to start was 30 and they advised adding 5lbs of CYA. After testing I was at 90 and my primary chlorine is trichlor pucks(which I realize also adds CYA).
I am going to do a water replacement and based on the high CYA i need to do about 2/3rds of the pool for water replacement?
Currently my pool is green and I believe I should do the water swap first. Then I should retest and add alkalinity first, then PH and then calcium and then should I SLAM the pool?
I was doing pretty well up until 2 weeks ago and want to get it back up and swimmable asap. Thank you for any help in advance
