Think maybe this would be a proper place to ask another CYA question. I have seen on this forum and other forums that for a proper cya test the tested water should be between 70 to 75 Degrees F. If this is true does the pool tester need to cool down 90 degree F water to the 70 degree F before performing the test? Ex. put that 90 degree sample water in a frig for a while to the acceptable 70 degree level????
