As the title reads, my CYA is down to 40 (from 50 at setup of pool). And, my pH is reading at 8.2 for the past 3 days. pH fluctuates a little from time to time... it has always been between 7.8 and 8.2 though. I didn't expect CYA to change much at all. But it is definitely lower than where it started. Should I worry about these two numbers? Are there adjustments that I could make that would regulate both so they're more in range?
Adding: I have Cyanuric Acid to increase CYA numbers. That is no problem. But, I haven't invested in Muriatic acid yet. I was planning on draining my pool first and dealing with muriatic if needed, after the refill. But, should I worry about lowering ph now, before I drain and refill?
Adding more: So I was just reading this post: PH - Further Reading and it seems that it MIGHT be better not to read pH just after adding chlorine (I usually add chlorine and then test water again 30-45 minutes later). Is testing pH close to liquid chlorine addition raising my pH numbers artificially? Should I wait longer before retesting pH after adding chlorine? In reading the whole post, it seems my pH wants to stay at 7.8 to 8.2. So should I just accept that or try to adjust it?
