Hey guys,
Just opened the pool a couple days ago. Thanks to you guys a bought a taylor test kit and starting doing the pool by myself. Anyway, opened the pool and it was filled with algae(had to close late due to cover being made). Used liquid chlorine and made it blue but very cloudy. I think I understand why. Here’s my numbers on my 28K gallon pool.
PH: 7.0
Alkalinity : 70
Cya: 100
FC: 11
CC: .5
Calcium hardness: 150
Obviously my CYA is through the roof. I realize I would need my FC to be maintained significantly higher to SLAM.
I’ve begun partially draining the pool in segments. Draining roughly a quarter, then adding new water..etc. Will that work? I don’t want to drain too much as risk messing up the vinyl liner.
Additionally, do you think my CYA is way higher than 100, if so will I have to drain more than 1/2 the pool. How do I test? I read somewhere about diluting in tap water or something?
PH: 7.0
Alkalinity : 70
Cya: 100
FC: 11
CC: .5
