For that to be truly effective you need to separate the new water from the old. That is what the tarp method does.
At the bottom of the Pool Math page it tells you what each puck and bag will add to your pool. An example would be, each 8oz puck will add 1.7 ppm FC and 1ppm CYA to your pool. And the CYA doesn't go away so every day you are adding 3.4ppm of FC to makeup normal daily loss, you are adding 2 ppm CYA. so after 30 days you have added 60 ppm CYA. OUCH!
And that's not including all the "shock" you added.
