FC 2.5
CC .2 (See question below)
TC 2.7
PH 7.5 (Goes up when I add "fresh" water)
TA 180
CYA 58 (Previous 170 - drain/fill half, then 85 - drain/fill 18")
Temp 67
Ok, so I did it anyway. After 9 years of being out of wack in my pool chemistry, I want for it to be as close to perfect now as possible. I did't like the fact of being slightly on the high side with 85 CYA, so I did drain about 18" off to lower it slightly, so I would be in the 60-80 range, shooting for 65. Maybe I should have just stuck with the 85, but I didn't want the "extra" chlorine that would be needed. I know we can go around and around on that one. I just didn't want to be on the high side and need to drain the pool, I wanted to just get all of that behind me. If I need to add, I'll add, just no more draining. SO, now my CYA is 58, I overshot it a little. Is that good or should I add just a little.
So now that I think I have the CYA in hand, now I am focusing on the high TA. By the way, the pool is still just a little green, but probably 70% better than what it was. I just poured .5 gal acid to get the PH down, while doing a little aerating. I plan to build a rig similar to Duraleigh's tomorrow evening for proper aeration. Proceed through probably gallons of acid until I get the TA down.
Am I proceeding down the correct path? Is it wise to finish the algae battle while fighting the TA? Or do them both? Oh, by the way, I found a left over jug of 20% algaecide, so I tossed it in, the algaecide, not the jug. I don't remember the ounces, maybe 1/2 gal or so.
My CC question. I do the FC portion of the chlorine test. No problems. I add the 5 drops of R-0003, and if sample turns back to pink, I have CCs. Ok, it goes to a very light pink. ?? If at that point I add the R-0871 until clear the multiple time .5, I loose the logic. The sample is immediately clear after the first drop of R-0871, multiplied by the .5 gives me .5, instantly too high for CC. Any shade of pink will put you too high on CC. OR am I COMPLETELY missing the point, overlooking the obvious??? I see other's test results with a .2, how can you get that. This is probably going to be another "stupid" question, but I've heard there is no such thing, so ... . .
Thanks again for all of the help,
Starting to see the glimmer at the end of the tunnel. Hope it's not a train. If so, I'm jumping on.
Mister Mister
