- Jul 27, 2017
- 82
- Plaster
- Pentair Intellichlor IC-40
I just read this article and I'm very interested in thoughts around it: Cyanuric acid: friend or foe of swimming pools?
Quote from the article:
Over the years, numerous independent and academic research has come to show that when cyanuric levels build up in the pool, ORP levels consistently drop indicating that the effectiveness of chlorine diminishes. In addition, there is a clear correlation to increased levels of cyanuric acid and the time it takes to effectively kill bacteria present in pool water. The chart below demonstrates the amount of time to kill 99 percent of bacteria at various levels of cyanuric acid and different levels of chlorine. Taking one example from the data, at cyanuric acid levels of 100 ppm, it takes 20 to 50 times the amount of time to kill 99 percent than at 0 ppm of cyanuric acid.
I'm thinking of just caping mine out at 50 and leaving it there - but most of the data around TFP (given my pool setup/type) suggests I should be closer to 70.
Trying to learn here... just want to do the right thing by the pool and by the people (my family and friends) who will be swimming in it.
Thank you for any thoughts!
