Hi
I’m going to be fitting a SWG and would like some advice on CYA level.
I have a pool enclosure which “sort of” makes it like an indoor pool so I maybe can get away with having a much lower CYA level as the UV load is low.
however, in the summer the sun does occasionally shine here in the U.K. ( when it’s not raining) and so we do open the enclosure letting in the sun.
So would it cause any harm to run the CYA at the bottom end of the recommended levels ( say60ppm) ?
Additionally I read that adding Borax is good for stabilising the pH. It seems that Borax is banned in Europe and so I can’t find anywhere that sells it! So is it a problem to skip the Borax and if so what do I need to watch out for?
Thanks in advance for any guidance.
Cheers
Ian
Cheers
Ian
