I just opened the pool 1 week ago. It was clear and things are looking good so far. We had a cold spring here in Michigan, which helped the pool not turn in to a swamp. Chemical balance looks good, with the exception of CYA. Here are my numbers from the TF100 kit (got a new one this year to replace my last, so everything is new).
FC - 8
TA - 130
PH - 7.2
CYA - 100+ (I haven't done the diluted test yet, but assume it's higher)
I normally use the pucks in a chlorinator, which I know is not recommended here. I've owned the pool for 5 full seasons, this being the start of the 6th. I used to drain almost half of the pool each closing in the fall (below the return lines and deep end is only 6 feet deep), which helped me to replace enough water to remove CYA to zero over the cold winters here in Michigan. 2 years ago we got a new vinyl liner, which also has the liner over the steps in the shallow entry. The pool company says we should not drain like we used to any longer to prevent the steps from getting messed up. Because of this I don't have water replacement to reduce CYA over the winter.
My question here is, the water looks great right now. But that seems temporary with CYA being high. The water temp has been 58 degrees since opening last week. Do you expect algae to take off as soon as the water temp rises?
FC - 8
TA - 130
PH - 7.2
