Novicetrish
12
PA
Hi. I have a concrete pool with several cracks in a home I bought. We are trying to bring the pool back to life. They have been opened up and most do not penetrate the plaster layer. The ones that do are less than 1 inch deep. Can these just be plastered or do I need epoxy/staples?
They seem minor to me and I dont want the solution to be more aggressive than the problen. To the best of my knowledge the pool does not leak and if it does it is only around the waterline. All tile and coping is bring replaced. Thanks so much for any advice you can give
Post wider pics showing the crack with the pool and coping.
Is there only that one crack?
The plaster around the crack needs to be be totally removed to see if the gunite shell has cracks.
