Hi all,
i am am pretty sure I have a crack/leak in my suction line.
symptoms
If I turn off the pump for a few days and then start it up the water (visible via pump glass) is clear at first and then for a few seconds turns dirty/muddy before returning to clear again.
The longer I leave the pump off before running, the more dirty water.
Note: Leaving the pump off for long periods does not cause it to loose prime/suction.
I have 1 skimmer, and 1 drain.
We did have a unusually extra cold winter here in the UK however I did run the pump constantly on freezing days to try to minimise any damage.
Question;
Where are the most common likely places of cracks? I see there are a few companies offering services of leak detection without major digging work.
symptoms
Question;
