Hello all. First post, and unfortunately about the title. I inherited a Clearflo DE filter for the 16x32' inground pool that came with our house. The model number is unreadable, and it has been tough to find any information online about it (the pool was installed 30 years ago, so I assume the filter is close to that age).
I know I'm probably at the point where I should replace it anyway, but I'd rather not budget that expense right now if possible. Reading other posts, it seems like a drain plug crack means time to replace the unit. I've done some DIY indoor plumbing work, but I'm a total novice when it comes to pool plumbing. I managed to get it pretty snug with the clamp that was on it (apparently this isn't a new problem), so there's one drop every 5 seconds. Is that piece that's crack something that can be taken off and refitted if it's just a nut? Obviously, I don't want to mess around with it an make the damage worse.
And if anyone knows what type of filter I have, that's a bonus
Thanks in advance!
Thanks in advance!
