I'm talking with some pool concrete individuals to gather quotes and best approach to fixing what has become extremely bad cracking in our pool deck concrete. The cracks originate from the anchors that were installed back when the pool was built in 2004. The anchors used were aluminum. And the railing used was a set of "deck mounted 2 bend handrails" on either side of the steps. They are 40" width (supposedly).
The first question that came up was cutting out the cracked area of concrete and just replacing that vs removal of the whole section. The whole section is easily 10x the area of where the cracking is. I've been told they can cut out the cracked concrete, tie rebar into the existing concrete, and pour new. I'm no concrete expert but I can't imagine the old and new concrete would ever bond like freshly pouring the slab.
Second thing that I'm curious about is that one individual recommended moving to a different type of center mounted railing instead of the 2 on the sides. He seemed to imply that the side railings were more prone to cracking the concrete. This doesn't make any sense to me and from my research it seems like there are plenty of people with cracking from a center rail. Is there any validity to this?
I don't want a center rail. The pools steps are 4ft at the bottom step and a bit under 6ft at the top step. A center rail seems like it would intrude and crowd the steps.
The other question I have is replacing the anchors. I think that the aluminum anchors were a poor choice and probably contributed to the cracking. I've seen brass is recommended now. But I also came across the polymer based anchors from Saftron (and their railings). I sort of feel like the polymer anchors might be even better option over the brass. Curious if anyone has thoughts.
Finally, I was thinking we should replace the railings we have. I think they are an old S.R. Smith model. They have been extremely difficult to insert for many years now. I measured them and the center-to-center measurement doesn't seem like 40" but more like 40.5". I think this was why they've been so hard to insert for so long and might have even contributed to the concrete cracking. I was considering maybe moving to the polymer based Saftron railing in the same style. However, I don't really know anything about it. Are they worth it? Are there better options (that are still economical)? Are they going to be more resistant and longer lasting to chlorine or if we switch over to a salt to chlorine generator?
Thanks.
Thanks.
