Cover Motor
May 6, 2015
13
Lima, OH
My motor went out last fall. Thank goodness the pool was already closed for the winter. The cover is currently completely extended out in the closed position. I've had 2 companies tell me not to try to install the pool cover motor by myself because it's not just a simple motor swap, you have to adjust the ropes and other stuff(??). BUT, these 2 companies are in a pretty fierce competition with each other and do price gouge in my opinion, they are the only 2 around my area. However, from what I see on youtube and reading forums such as this one, it looks to be a simple swap!! The replacement motor for my cover is a little over $1,000.00 but they are charging an extra $1,500.00 to put it in. I am very mechanical, but I'd like for someone to confirm that this simply is a motor swap. Seems to me that as long as the shafts are lined up, it should be easy since the cover is all the way closed, but I don't want to get halfway into this and find out differently. lol
Any help is appreciated, thank you.
Circling back around on this one for advice, (Thanks for your reply Bama Rambler),
I haven't bought the replacement motor yet. I did take the housing apart and the pool guys were right, there is a lot of slack rope just laying around in the box. The cover is all the way extended too, so I wouldn't think there would be this much slack. This makes me somewhat questioning if I want to try this myself. I assume this slack in the ropes just need wrapped around the pulleys until tight before I actually install and run the new motor (when I buy it)? Thank you
