Given your ever decreasing CC number I suspect you have crossed the hump and things will get easier soon.
Ike
Ike
iam4iam said:Is it not safe to assume (dangerous word, I know) that if some is left undissolved that there is enough?
Isaac-1 said:if it were mine after all that work, I might boost the FC one last time just to be safe. You will then want to fine tune your CYA and other levels (TA, etc.).
Any ideas on CH? Is it really supposed to turn blue (not purple)?
kb239 said:The book recommends an addition of five or six drops of titrant (Hardness Reagent) to the water supply first then conduct the test as usual. The titrant " ties up" the interfering soluble metals and the test can then be completed with a distinct endpoint. Count the drops of titrant used to reach the endpoint plus the drops initially added to obtain the total number of drops used.' Hope this helps.
Have you read the cya extended test kit directions?iam4iam said:As for CYA, since I'm still not confident with the test
That will differ greatly from pool to pool. Temperature, bather load, hours of direct sunlight, sunlight angle, organics getting into the pool, etc. in addition to cya concentration can affect it. With that said, I seems like a pool that does not have bathers in or getting organics can be around 2-3 ppm/day. Again that is a generalization! If you are going to adjust, and since it can be quite an iterative process, start low and go higher slowly. Remember cya easy in, drain/refill out.iam4iam said:it sounds silly, but is there any reason not to adjust gradually based on daytime FC loss? What would be a typical daytime FC loss on a sunny day with the proper level of CYA?
