- Jun 1, 2018
- 16,094
- Vinyl
- Hayward Aqua Rite (T-15)
Don’t back off now- the oclt a great sign but it’s not the only end of slam criteria for a reason.
Until the water is crystal clear (no algae, dead or alive) maintain slam level fc,
Keep filtering 24/7,
Backwash/clean the filter when pressure rises 25% over clean pressure,
Keep running the bot.
If fc is holding better then it shouldn’t be too hard to maintain slam level.
Put on your patience pants & carry on
You mentioned the inline chlorinator
that should only be used for vacations really.
Using pucks for daily chlorination continuously increases your cya which in turn raises the bar for minimum, target, & slam fc levels which will put you back in this situation in short order.
To prevent this, keep your pool on the liquid chlorine diet even after slam is complete unless you need a little cya boost or need to travel & your cya can stand the increase.
