- Sep 10, 2019
- 89
- Plaster
- Pentair Intellichlor IC-60
Hi all, I used my intellichem system for the last 2 years mostly successfully but this year I used dramatically more Cl so have messed with things a bunch. My plan is to use it to sense and adjust pH because it does well there but only use the CL side to pump a preset CL volume by controlling the dose/daily max.
My question is on the low side FC. My CYA is 40 and the last few days I have been waking up to FC = ~2.5 (no CC). The system is adding 80oz of liquid each morning, which takes me up to about 5.4 (this matches what Poolmath says it should be after 80oz). That means my Cl burn off is about 3.
Should I increase my dosage to get that min morning number up a bit or should I maybe bump CYA up to 50. I am trying to get my Cl consumption minimized.
Thoughts?
Thoughts?
