Converting Hayward Northstar single speed single pool pump to a VSP and Smart Switch/Timer installation
GoofustheDoofus
31
Katy, TX
For reference, my current setup - I am 2nd owner on this pool, and bought the house a few years back with the setup.
Been real solid and pretty trouble free to date - but my pump sounds like a dying squirrel and rather than just rebuild the old Northstar and continue forward with a single speed pump, would like to better my carbon footprint, save cash on electricity, etc. and graduate into a VSP.
I have been reading up on the potential issues with having a SWG and hooking that up off a 'constant on' VSP wiring situation, and the risk of timers being out of sync and the SWG exploding - I am a safety-first kind of person, and also a DIYer as I love learning and building and maintaining my house (I like knowing a job was done well, and if there is an issue, it is my fault and I remedy it!).
So that said, here is a diagram of what I was thinking, to combat this SWG/VSP power issue + add a bit more smart automation to my setup (I have been building a smart house to a certain extent already with around 80 devices in the house... pool pump automation is long due!)
Thoughts:
  • I have a wi-fi switch on the VSP, that is 'always on' but allows me to do a 'kill power' to the system if I am away from home and TX has another stellar power outage that messes up the local clock on the VSP and settings
  • I power the pool cleaner pump off a switch for more flexibility on cleaning schedule - nothing big to report there
  • The SWG is on a wifi switch as well - so I have 'zero clock sync issues' with the power source between the SWG and the primary pool pump.
    • Yes - I recognize that if there was a power outage and I have the ability to remotely check all my all my wi-fi switches are on 'correct time' - BUT unless I manually check the VSP's local schedule on the pump controller itself to make sure there was not a clock sync issue - they could be out-of-sync
    • that said, if I am out of town and this happens, I can just use the wi-fi control to kill power to all 3 devices, and deal with the pool issues when back in town
Soliciting thoughts on this setup, any flaws that you see? Is there any issue running a pump like a Pentair IntelliFlo off of a switch - if you plan to give it power 24/7 unless you have a one of incident and shut down all power?
As a retired Fire Chief and safety oriented person, I have one comment. You are way overthinking this safety issue. With the onboard controller/timer on the pump and an Intermatic timer for the SWG, you already have a “belt and suspenders” system. The timer just needs to be set to turn the SWG on 30 min after the pump is set to start, and off 30 min before it stops. Should the timers get out of sync or something fail, you still have a flow switch on the SWG that will prevent it from being powered without a flow.
Its not that I’m against using smart switches. In fact I’m using one of the 220v switches for my spa pump, and several 110v ones for the heater, light, etc.
Why wouldn't a single switch control the SWG and the pump? That way the SWG can only be on if the pump is. If your saying the Intelliflow has its own schedule via the keypad, then yes I can see where the pump would be off but power going to the SWG. However, in this case, if you cut power to the pump, and turn it on, does it start its schedule from the beginning? Does it store its schedule for a certain perdiod of time? I looked into adding a vgreen VS pump and thats how they work. In this case it would be fine.
BTW, I had the Aquarite SWG like you do. Sold it on ebay for a few hundred (cell not included), and took that money and bought a Prologic PL4 Panel. Nice step up to automation.
@kevreh - my thoughts on not having the SWG and pump on the same switch was, I could use that wifi switch to set the schedule for the SWG to run a separate schedule from the pool pump. As in - let's say with the new variable speed pump I run a lower rate for a longer period of the day - like 12 hours or something - I don't have to run the SWG that full 12 hours. I could program the Pump on the pump itself to run the 12 hour schedule, and program the SWG through the wifi switch to only be 'on' for 8 hours a day (or whatever time i determine gets my FC level where I want it).
RE: the Prologic PL4 panel - does that give you the ability to control your SWG on/off time + your pool pump schedule all in one place? That would solve some of my issues here, I am still deep in the 'research' phase here on what pump I want to buy, but struggling to find a simple system that integrates a SWG and VSP settings without being a $1000+ 'automation' system where I don't need any other features... I have no spa, no lights, no valves, no heater, etc. to try and control. Just simply primary pool pump, cleaner pump, and SWG.
@chiefwej - those are good points as well. I guess on first pass I am happy to hear it seems I am overthinking it as opposed to underthinking it!
I like your approach around the smart switches - I use Kasa for the majority of my switches/bulbs (around 30 or so) and I would love to add more to stay with a single app there... but unfortunately they don't have 220V options! That space really seems to be limited in the market...
Thus I am considering these DEWENWILS Outdoor Smart Wi-Fi Outlet Box, Heavy Duty 40A 120-277 VAC 2HP Wireless Controller Timer Switch for Pool Water Heater SPA, Compatible with Smart Phone, Alexa, Google Assistant, UL Listed: Amazon.com: Industrial & Scientific (they look super similar to the ones you used)
I wanted to update this thread - those Dewenwils outdoor smart outlet boxes had a critical failure on me and I have since replaced them with a pair of these Z-wave GE models: https://www.amazon.com/120-277VAC-E...tric+water+heaters,+14285,+gray,aps,70&sr=8-1
Long & Short - I was about to leave for a family trip with a 6 hour drive, I was checking pool equipment before I left and the Dewenwils units had lost their connection to my wi-fi. There was no notice in the system this occurred, and when trouble shooting through the company they did not have a reason why for me, but suggested I delete and re-install the app, etc. to get them to connect. This did not work at first, but after several tries I got them to connect again, but they fact that they just 'deleted' themselves from my network was no good. It caused my booster pump not to run and my SWG not to produce chlorine, if I had not seen this it could have been bad for the pool chemistry and cleanliness and on top of that, if they somehow 'came back' online out of sync with everything my SWG could have been running without my pentair pump.
The GE units are Z-wave, more reliable thus far, and integrate with my Amazon Alexa routines, so thus far while they cost more $, I would recommend them if somebody was replicating this setup.
Reactions: Lanzz
I wanted to update this thread yet again!
Frankly - the GE Z-wave units were unreliable for me through my Ring & Amazon Alexa applications. It would say that it had carried out the routine to turn them on sometimes - and in fact it had not. I just could not live with this type of uncertainty.
I have since switched to these units: https://www.amazon.com/gp/product/B07TVKSDD4/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
They are NOT smart boxes, but they are digital timers with battery backup. The reason I like these, and have had good success to date:
- Not relying on any internet connections or smart connections for them to work
- battery backup is nice when power flops like it does in TX. My previous mechanical timers used to not respond well to a temporary power outage, I would have to manually reset them
- you can have these setup to not automatically change with daylight savings time. Since my pentair pump does not auto-adjust for daylight savings time easier, it is nice that these switches and my pump are more likely to stay 'close in time' (although the pentair pump internal clock sucks in my eyes - it does not keep good time, and needs to be adjusted every couple months).
So wanted to give that update - that both the wifi and Z-wave boxes were not reliable in my experience. I have thus gone back to digital timers - that are programmed locally, and they have been running for months with no problems.
